Public Sub SetTextProperties( _ ByVal textProperties As TextProperties _ )
public void SetTextProperties( TextProperties textProperties )
Parameters
- textProperties
- TextProperties
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//Create a dynamic text element.
//Set the string with tags and the location
String title = @"<dyn type = ""page"" property = ""name"" />";
Coordinate2D llTitle = new Coordinate2D(6, 2.5);
//Create with default text properties
//Note: Must be on QueuedTask.Run
TextElement titleGraphics = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PointText, llTitle.ToMapPoint(), null, title) as TextElement;
//Modify the text properties
titleGraphics.SetTextProperties(new TextProperties(title, "Arial", 24, "Bold"));
//Update text element properties for an existing text element.
// Reference and load the layout associated with the layout item
if (layout != null)
// Reference a text element by name
TextElement txtElm = layout.FindElement("MyTextElement") as TextElement;
if (txtElm != null)
double x = 2.0;
double y = 3.0;
// Change placement properties
txtElm.SetAnchor(Anchor.CenterPoint);
txtElm.SetX(x);
txtElm.SetY(y);
// Change TextProperties
TextProperties txtProperties = new TextProperties(
"Hello world", "Times New Roman", 48, "Regular");
txtElm.SetTextProperties(txtProperties);
