ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructHatchFill Method / ConstructHatchFill(CIMStroke,Double,Double,Double) Method
ArcGIS.Core.CIM.CIMStroke
The angle for the hatch pattern.
The separation for the hatch pattern.
The offset value. ArcGIS.Core.CIM.CIMHatchFill.OffsetX and ArcGIS.Core.CIM.CIMHatchFill.OffsetY will get set to this value.
Example
    Constructs a hatch fill with the specified parameters.
    Syntax
    Public Overloads Function ConstructHatchFill( _
       ByVal lineStroke As CIMStroke, _
       ByVal angle As Double, _
       ByVal separation As Double, _
       Optional ByVal offset As Double _
    ) As CIMFill
    Parameters
    lineStroke
    angle
    separation
    offset
    Return Value
    Example
    Cross hatch
    /// <summary>
    /// Create a polygon symbol using the ConstructHatchFill method . <br/>
    /// ![PolygonSymbolDiagonalCrossHatch](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/ConstructHatchFill.png)
    /// </summary>
      CIMStroke lineStroke = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(51, 51, 51, 60), 4, SimpleLineStyle.Solid);
      //gradient
      var hatchFill = SymbolFactory.Instance.ConstructHatchFill(lineStroke, 45, 6, 0);
      List<CIMSymbolLayer> symbolLayers = new()
        hatchFill
      //This is the polygon symbol with a diagonal cross hatch fill
      CIMPolygonSymbol crossHatchPolygonSymbol = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() };
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = crossHatchPolygonSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Dash dot fill
    /// <summary>
    /// Create a polygon symbol with a dash dot fill. <br/>
    /// ![PolygonSymbolDashDot](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-dash-dot.png)
    /// </summary>
      //Note: Run withing QueuedTask
      var trans = 50.0;//semi transparent
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid);
      //Stroke for the fill
      var dashDot = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 1.0, SimpleLineStyle.DashDotDot);
      //Mimic cross hatch
      CIMFill[] solidColorHatch =
               new CIMHatchFill()
                  Enable = true,
                  Rotation = 0.0,
                  Separation = 2.5,
                  LineSymbol = new CIMLineSymbol(){SymbolLayers = new CIMSymbolLayer[1] {dashDot } }
               new CIMSolidFill()
                  Enable = true,
                  Color = ColorFactory.Instance.CreateRGBColor(255, 255, 0)
      List<CIMSymbolLayer> symbolLayers = [outline, .. solidColorHatch];
      //This is the polygon symbol with a dash dot fill
      CIMPolygonSymbol dashDotFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() };
      //renderer.Symbol = dashDotFillPolygon.MakeSymbolReference();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
