ArcGIS.Desktop.Mapping Namespace / CameraTrack Class / CreateKeyframe Method / CreateKeyframe(Camera,TimeSpan,AnimationTransition) Method
The value of the camera.
The time at which to insert the keyframe in the track. In the UI the default is ArcGIS.Core.CIM.AnimationTransition.FixedArc.
The transition for keyframe.
Example
    Create a new keyframe.
    Syntax
    Public Overloads Function CreateKeyframe( _
       ByVal camera As Camera, _
       ByVal atTime As TimeSpan, _
       ByVal transition As AnimationTransition _
    ) As Keyframe
    Parameters
    camera
    atTime
    transition
    Remarks
    If a keyframe already exists at that time it will be overwritten. The time is rounded to the nearest millisecond. When you create a keyframe the specified transition will be used for all the values of the camera. It is possible to change the transitions for the individual values of the camera by settting the transition for the value on the keyframe./>
    Example
    Create Camera Keyframe
      var animation = mapView.Map.Animation;
      var cameraTrack = animation.Tracks.OfType<CameraTrack>().First(); //There will always be only 1 CameraTrack in the animation.
      cameraTrack.CreateKeyframe(mapView.Camera, atTime, AnimationTransition.FixedArc);
    Requirements
