ArcGIS.Desktop.Mapping Namespace / HeatMapRendererDefinition Class / HeatMapRendererDefinition Constructor / HeatMapRendererDefinition Constructor(CIMColorRamp,String,Int32,Int32,String,String)
(Optional) Controls the color scheme of the heat map. If no color scheme is specified, a default color ramp will be used.
(Optional) Name of the field denoting weighting values for each feature.
(Optional) Controls how far the heat spreads away from the points.
(Optional) Controls the pixilation of the raster. This is an arbitrary range that goes from Best (10) to Fastest (0).
(Optional) Used in the legend to denote the maximum value in the color scheme.
(Optional) Used in the legend to denote the minimum value in the color scheme.
    Create a HeatMapRendererDefinition.
    Syntax
    Public Function New( _
       ByVal colorRamp As CIMColorRamp, _
       ByVal weightField As String, _
       Optional ByVal radius As Integer, _
       Optional ByVal renderingQuality As Integer, _
       Optional ByVal upperLabel As String, _
       Optional ByVal lowerLabel As String _
    Parameters
    colorRamp
    weightField
    radius
    renderingQuality
    upperLabel
    lowerLabel
    Remarks
    Only applicable for point feature layers.
    Requirements
