ArcGIS.Desktop.Mapping Namespace / LayerTrack Class / CreateKeyframe Method
The layer associated with the keyframe.
The time at which to insert the keyframe in the track.
A value indicating if the layer is visible.
The value of the transparency.
The transition for the transparency of the layer. In the UI the default is ArcGIS.Core.CIM.AnimationTransition.Linear.
Example
    CreateKeyframe Method (LayerTrack)
    Create a new keyframe.
    Syntax
    Public Function CreateKeyframe( _
       ByVal layer As Layer, _
       ByVal atTime As TimeSpan, _
       ByVal isVisibile As Boolean, _
       ByVal transparency As Double, _
       ByVal transition As AnimationTransition _
    ) As Keyframe
    Parameters
    layer
    atTime
    isVisibile
    transparency
    transition
    Remarks
    If a keyframe already exists at that time it will be overwritten. The time is rounded to the nearest millisecond.
    Example
    Create Layer Keyframe
      var animation = mapView.Map.Animation;
      var layerTrack = animation.Tracks.OfType<LayerTrack>().First(); //There will always be only 1 LayerTrack in the animation.
      layerTrack.CreateKeyframe(layer, atTime, true, transparency, AnimationTransition.Linear);
    Requirements
