ArcGIS.Desktop.Mapping Namespace / Map Class / FindLayer Method
The URI of the layer. Which is unique identifier for each layer
(optional) When true the search continues in group layers. (default value = true)
Example
    FindLayer Method (Map)
    Finds a layer using a URI.
    Syntax
    public Layer FindLayer(
       string layerURI,
       bool recursive
    Public Function FindLayer( _
       ByVal layerURI As String, _
       Optional ByVal recursive As Boolean _
    ) As Layer
    Parameters
    layerURI
    recursive
    Return Value
    Example
    Find a layer
      //Finds layers by name and returns a read only list of Layers
      IReadOnlyList<Layer> layers = map.FindLayers("cities", true);
      //Finds a layer using a URI.
      //The Layer URI you pass in helps you search for a specific layer in a map
      var lyrFindLayer = MapView.Active.Map.FindLayer("CIMPATH=map/u_s__states__generalized_.xml");
      //This returns a collection of layers of the "name" specified. You can use any Linq expression to query the collection.
      var lyrExists = MapView.Active.Map.GetLayersAsFlattenedList()
                         .OfType<FeatureLayer>().Any(f => f.Name == "U.S. States (Generalized)");
    Requirements
