ArcGIS.Desktop.Mapping Namespace / Map Class / GetSelection Method
Example
    GetSelection Method (Map)
    Get the selection for the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public SelectionSet GetSelection()
    Public Function GetSelection() As SelectionSet
    Return Value
    The selection in the map represented by the collection of layers and tables and their corresponding object ids.
    Exceptions
    ExceptionDescription
    Example
    Check SelectionSet Equality
      // get map selection
      var mapSelSet = MapView.Active.Map.GetSelection();
      // create a selectionSet
      var selDict = new Dictionary<MapMember, List<long>>();
      selDict.Add(featureLayer, new List<long> { 1506, 2696, 2246, 1647, 948 });
      var layerSelSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(selDict);
      // test for equality - use Equals method
      var isEquals = mapSelSet.Equals(layerSelSet);
      // test for equality - use operators
      var equals = mapSelSet == layerSelSet;
      var notEquals = mapSelSet != layerSelSet;
    Flash selected features
      await QueuedTask.Run(() =>
        //Get the selected features from the map and filter out the standalone table selection.
        var selectedFeatures = mapView.Map.GetSelection();
        //Flash the collection of features.
        mapView.FlashFeature(selectedFeatures);
    Requirements
