ArcGIS.Desktop.Mapping Namespace / Map Class / RemoveBookmark Method
The bookmark to remove.
Example
    Removes the bookmark from the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void RemoveBookmark(
       Bookmark bookmark
    Public Sub RemoveBookmark( _
       ByVal bookmark As Bookmark _
    Parameters
    bookmark
    Exceptions
    ExceptionDescription
    Example
    Remove bookmark with a given name
      await QueuedTask.Run(() =>
        //Find the first bookmark with the name
        var bookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
        if (bookmark == null)
          //Bookmark not found
        //Remove the bookmark
        mapView.Map.RemoveBookmark(bookmark);
    Requirements
