ArcGIS.Desktop.Mapping Namespace / Map Class / SetSelection Method
The SelectionSet used to set the map selection.
Combination method used in the selection operation.
Example
    SetSelection Method (Map)
    Set the selection in the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    selectionSet
    method
    Return Value
    The selection created in the map.
    Exceptions
    ExceptionDescription
    Example
    Clear all selection in an Active map
      await QueuedTask.Run(() =>
        mapView.Map?.SetSelection(null);
    Requirements
