ArcGIS.Desktop.Mapping Namespace / MapView Class / PanToAsync Method / PanToAsync(Camera,Nullable<TimeSpan>) Method
The new camera to use for the view.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
    Pan the view to a camera position.
    Syntax
    Public Overloads Function PanToAsync( _
       ByVal camera As Camera, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    Parameters
    camera
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    Pan in 2D maintains the current camera scale and heading and modifies the X and Y position. Pan in 3D maintains the current camera pitch and heading and modifies the X and Y position. If the camera's spatial reference is in a different spatial reference than the map this method projects the camera into the spatial reference of the map.
    Requirements
