ArcGIS.Desktop.Mapping Namespace / MapView Class / PanToAsync Method / PanToAsync(Bookmark,Nullable<TimeSpan>) Method
The bookmark containing the position in which to pan.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Pan the view to the position defined in a bookmark.
    Syntax
    Public Overloads Function PanToAsync( _
       ByVal bookmark As Bookmark, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    Parameters
    bookmark
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    Pan in 2D maintains the current camera scale and heading and modifies the X and Y position. Pan in 3D maintains the current camera pitch and heading and modifies the X and Y position.
    Example
    Pan To Bookmark Async
      //Get the first bookmark with the given name.
      var bookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
      if (bookmark == null)
        // Manage the error - bookmark not found
      //Pan the view to the bookmark.
      mapView.PanToAsync(bookmark, TimeSpan.FromSeconds(2));
    Requirements
