ArcGIS.Desktop.Mapping Namespace / MapView Class / PanToAsync Method / PanToAsync(Layer,Boolean,Nullable<TimeSpan>) Method
The layer containing the features in which to pan.
Indicates whether only the selected features for a layer should be used to determine the extent in which to pan.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
    Pan the view to the extent of a layer.
    Syntax
    Public Overloads Function PanToAsync( _
       ByVal layer As Layer, _
       Optional ByVal selectedOnly As Boolean, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    Parameters
    layer
    selectedOnly
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    Pan in 2D maintains the current camera scale and heading and modifies the X and Y position. Pan in 3D maintains the current camera pitch and heading and modifies the X and Y position.
    Requirements
