ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToAsync Method / ZoomToAsync(Camera,Nullable<TimeSpan>) Method
The new camera to use for the view.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Zoom the view to a camera position.
    Syntax
    Public Overloads Function ZoomToAsync( _
       ByVal camera As Camera, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    Parameters
    camera
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    This is equivalent to setting the camera position for the view. Use this method in combination with Camera to get and then modify the position of the view's camera. If the camera's spatial reference is in a different spatial reference than the map this method projects the camera into the spatial reference of the map.
    Example
    Rotate the map view
      //Get the camera for the view, adjust the heading and zoom to the new camera position.
      camera = mapView.Camera;
      camera.Heading = heading;
      await mapView.ZoomToAsync(camera, TimeSpan.Zero);
      //Or synchronously
      mapView.ZoomTo(camera, TimeSpan.Zero);
    Requirements
