ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToAsync Method / ZoomToAsync(Bookmark,Nullable<TimeSpan>) Method
The bookmark containing the position in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Zoom the view to the position defined in a bookmark.
    Syntax
    Public Overloads Function ZoomToAsync( _
       ByVal bookmark As Bookmark, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    Parameters
    bookmark
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Example
    Zoom Async To Bookmark by name
      await QueuedTask.Run(() =>
        //Get the first bookmark with the given name.
        var bookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
        if (bookmark == null)
          // Manage the error - bookmark not found
        //Zoom the view to the bookmark.
        mapView.ZoomToAsync(bookmark, TimeSpan.FromSeconds(2));
    Requirements
