ArcGIS.Desktop.Mapping Namespace / RangeTrack Class / CreateKeyframe Method
The value of the range.
The time at which to insert the keyframe in the track.
The transition for min and max value of the range. In the UI the default is ArcGIS.Core.CIM.AnimationTransition.Linear.
Example
    CreateKeyframe Method (RangeTrack)
    Create a new keyframe.
    Syntax
    Public Function CreateKeyframe( _
       ByVal range As Range, _
       ByVal atTime As TimeSpan, _
       ByVal transition As AnimationTransition _
    ) As Keyframe
    Parameters
    range
    atTime
    transition
    Remarks
    If a keyframe already exists at that time it will be overwritten. The time is rounded to the nearest millisecond. When you create a keyframe the specified transition will be used for the min and max values of the range. It is possible to change the transitions for the min or max by settting the transition on the keyframe./>
    Example
    Create Range Keyframe
      var animation = mapView.Map.Animation;
      var rangeTrack = animation.Tracks.OfType<RangeTrack>().First(); //There will always be only 1 RangeTrack in the animation.
      rangeTrack.CreateKeyframe(range, atTime, AnimationTransition.Linear);
    Requirements
