/// <summary>
/// Create a line symbol with the markers placed at a 45 degree angle. <br/>
/// </summary>
//Create a line symbol with the markers placed at a 45 degree angle.
//Create a marker from the "|" character. This is the marker that will be used to render the line layer.
//Note: Run withing QueuedTask
var lineMarker = SymbolFactory.Instance.ConstructMarker(124, "Agency FB", "Regular", 12);
//Default line symbol which will be modified
CIMLineSymbol lineSymbolWithMarkersAtAngle = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid);
//Modifying the marker to align with line
//First define "markerplacement"
CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize()
AngleToLine = true,
PlacementTemplate = new double[] { 5 }
//assign the markerplacement to the marker
lineMarker.MarkerPlacement = markerPlacement;
//angle the marker if needed
lineMarker.Rotation = 45;
//assign the marker as a layer to the line symbol
lineSymbolWithMarkersAtAngle.SymbolLayers[0] = lineMarker;
