ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructPolygonSymbol Method / ConstructPolygonSymbol(CIMColor,SimpleFillStyle,CIMStroke) Method
ArcGIS.Core.CIM.CIMColor
SimpleFillStyle
ArcGIS.Core.CIM.CIMStroke
Example
    Constructs a polygon symbol of specific color, style and outline.
    Syntax
    Public Overloads Function ConstructPolygonSymbol( _
       ByVal color As CIMColor, _
       ByVal fillStyle As SimpleFillStyle, _
       ByVal outline As CIMStroke _
    ) As CIMPolygonSymbol
    Parameters
    color
    fillStyle
    SimpleFillStyle
    outline
    Return Value
    Remarks
    Passing null for outline will create a polygon symbol without an outline.
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    How to construct a polygon symbol of specific color, fill style and outline
        CIMStroke outline = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
        CIMPolygonSymbol fillWithOutline = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, outline);
    How to construct a polygon symbol without an outline
        CIMPolygonSymbol fillWithoutOutline = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null);
    Requirements
