ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructPolygonSymbol Method / ConstructPolygonSymbol(CIMFill,CIMStroke) Method
ArcGIS.Core.CIM.CIMFill
ArcGIS.Core.CIM.CIMStroke
Example
    Constructs a polygon symbol from a fill and an outline.
    Syntax
    Public Overloads Function ConstructPolygonSymbol( _
       ByVal fill As CIMFill, _
       ByVal outline As CIMStroke _
    ) As CIMPolygonSymbol
    public CIMPolygonSymbol ConstructPolygonSymbol(
       CIMFill fill,
       CIMStroke outline
    Parameters
    fill
    outline
    Return Value
    Remarks
    Passing null for outline will create a polygon symbol without an outline.
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Requirements
