ArcGIS.Desktop.Mapping Namespace / ViewAnimation Class / GetTransparencyAtTime Method
The layer in the map.
The time at which to return the layer transparency.
    Gets the transparency of a layer at a specified time in the track. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public double GetTransparencyAtTime(
       Layer layer,
       TimeSpan time
    Public Function GetTransparencyAtTime( _
       ByVal layer As Layer, _
       ByVal time As TimeSpan _
    ) As Double
    Parameters
    layer
    time
    Exceptions
    ExceptionDescription
    Requirements
