ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Modify Method / Modify(AttributedRelationshipClassDescription) Method
Indicates the ArcGIS.Core.Data.AttributedRelationshipClass to be modified.
Example
    Enqueue the modify operation on the object referred to by the AttributedRelationshipClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    attributedRelationshipClassDescription
    Exceptions
    ExceptionDescription
    attributedRelationshipClassDescription has invalid relationship split policy, relationship rules, foreign keys,and/or intermediate fields.
    attributedRelationshipClassDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support attributed relationship classes.
    The relationship split policy is not supported.
    Example
    Modifying domain
      // Must be called within QueuedTask.Run
      void ModifyDomain(Geodatabase geodatabase, string codedValueDomainName = "Pipe")
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(codedValueDomainName)) as CodedValueDomain;
        CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomain);
        // Update domain description
        codedValueDomainDescription.Description = "Water Pipe Domain";
        // Adding code/value pair
        codedValueDomainDescription.CodedValuePairs.Add("C", "Copper");
        schemaBuilder.Modify(codedValueDomainDescription);
        // To modify the orders of coded value domain
        // schemaBuilder.Modify(codedValueDomainDescription,SortBy.Name,SortOrder.Ascending);
        schemaBuilder.Build();
    Removing subtype field designation
      void DeleteSubtypeField(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassDefinition);
        // Set subtype field to null to remove the subtype field designation
        featureClassDescription.SubtypeFieldDescription = null;
        schemaBuilder.Modify(featureClassDescription);
    Modifying subtypes
      void ModifySubtypes(SchemaBuilder schemaBuilder, TableDefinition tableDefinition)
        TableDescription tableDescription = new TableDescription(tableDefinition);
        // Remove the first subtype from the table
        IReadOnlyList<Subtype> subtypes = tableDefinition.GetSubtypes();
        tableDescription.SubtypeFieldDescription.Subtypes.Remove(subtypes.First().GetCode());
        // Adding a new subtype, 'Utility', in the existing table
        tableDescription.SubtypeFieldDescription.Subtypes.Add(4, "Utility");
        // Assigning 'Utility' subtype as the default subtype
        tableDescription.SubtypeFieldDescription.DefaultSubtypeCode = 4;
        schemaBuilder.Modify(tableDescription);
    Add relationship rules to a relationship class
      void ModifyRelationshipClass(SchemaBuilder schemaBuilder, AttributedRelationshipClassDefinition attributedRelationshipClassDefinition)
        AttributedRelationshipClassDescription attributedRelationshipClassDescription = new AttributedRelationshipClassDescription(attributedRelationshipClassDefinition);
        // Update the relationship split policy
        attributedRelationshipClassDescription.RelationshipSplitPolicy = RelationshipSplitPolicy.UseDefault;
        // Add field in the intermediate table
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("RelationshipStatus"));
        // Add relationship rules based on subtypes,if available
        // Assuming origin class has subtype with code 1
        attributedRelationshipClassDescription.RelationshipRuleDescriptions.Add(
          new RelationshipRuleDescription(1, null));
        // Enqueue modify operation
        schemaBuilder.Modify(attributedRelationshipClassDescription);
        // Execute modify DDL operation
    Modifying annotation labels and symbols
      void ModifyAnnotationLabelAndSymbols(SchemaBuilder schemaBuilder, AnnotationFeatureClassDefinition annotationFeatureClassDefinition)
        AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDefinition);
        IReadOnlyList<CIMLabelClass> labelClasses = annotationFeatureClassDescription.LabelClasses;
        // Adding a new annotation label class
        List<CIMLabelClass> modifiedLabelClasses = new List<CIMLabelClass>(labelClasses);
        modifiedLabelClasses.Add(new CIMLabelClass()
          Name = "RedSymbol",
          TextSymbol = new CIMSymbolReference
            Symbol = new CIMTextSymbol()
              Angle = 45,
              FontType = FontType.Type1,
              FontFamilyName = "Arial",
              FontEffects = FontEffects.Normal,
              HaloSize = 2.0,
              Symbol = new CIMPolygonSymbol
                SymbolLayers = new CIMSymbolLayer[]
                  { new CIMSolidFill { Color = CIMColor.CreateRGBColor(255, 0, 0) } },
                UseRealWorldSymbolSizes = true
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-RED"
        // Adding a  new symbol
        annotationFeatureClassDescription.Symbols.Add(new CIMSymbolIdentifier()
          ID = 1001,
          Name = "ID_10001",
            Angle = 43,
            FontEffects = FontEffects.Subscript,
            FontType = FontType.TTOpenType,
            FontStyleName = "Regular",
            FontFamilyName = "Tahoma",
            TextCase = TextCase.Allcaps
        // Modify annotation feature class
        AnnotationFeatureClassDescription modifiedAnnotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDescription.Name,
            annotationFeatureClassDescription.FieldDescriptions, annotationFeatureClassDescription.ShapeDescription,
            annotationFeatureClassDescription.GeneralPlacementProperties, modifiedLabelClasses);
        // Enqueue modify
        schemaBuilder.Modify(modifiedAnnotationFeatureClassDescription);
        // DDL execute
    Modifying an existing field
      void ModifyExistingField(SchemaBuilder schemaBuilder, TableDefinition tableDefinition, string fieldNameToBeModified = "PropertyAddress")
        Field field = tableDefinition.GetFields().FirstOrDefault(f => f.Name.Contains(fieldNameToBeModified));
        // Update field's alias name and length
        FieldDescription fieldDescription = new FieldDescription(field)
          AliasName = "Physical Property Address",
          Length = 50
        // Update the default value
        fieldDescription.SetDefaultValue("123 Main St");
        schemaBuilder.Modify(new TableDescription(tableDefinition), field.Name, fieldDescription);
        // Execute DDL
    Requirements
    ArcGIS Pro version: 3.1 or higher.
