ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / RemoveRelationshipClass Method / RemoveRelationshipClass(FeatureDatasetDescription,AttributedRelationshipClassDescription) Method
Indicates the ArcGIS.Core.Data.FeatureDataset where the ArcGIS.Core.Data.AttributedRelationshipClass will be removed.
Indicates the ArcGIS.Core.Data.AttributedRelationshipClass to remove.
Example
    Enqueue the Remove operation on the object referred to by the FeatureDatasetDescription and the AttributedRelationshipClassDescription.
    Syntax
    Parameters
    featureDatasetDescription
    attributedRelationshipClassDescription
    Exceptions
    ExceptionDescription
    The relationship split policy, relationship rules, and/or the origin foreign key fields are invalid.
    attributedRelationshipClassDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support attributed relationship classes.
    The relationship split policy is not supported.
    Example
    Adding/Removing Relationship class in/out of a feature dataset
      // Must be called within QueuedTask.Run
      void MoveRelationshipClass(SchemaBuilder schemaBuilder, FeatureDatasetDefinition featureDatasetDefinition, RelationshipClassDefinition relationshipClassDefinition)
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetDefinition);
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(relationshipClassDefinition);
        // Remove relationship class from the feature dataset
        schemaBuilder.RemoveRelationshipClass(featureDatasetDescription, relationshipClassDescription);
        // Add relationship class inside the feature dataset
        // schemaBuilder.AddRelationshipClass(featureDatasetDescription, relationshipClassDescription);
        schemaBuilder.Build();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
