ArcGIS.Core.CIM Namespace / CIMFieldDescription Class
Properties Methods Events
    CIMFieldDescription Class Members
    The following tables list the members exposed by CIMFieldDescription.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the field alias.
    Public Property Gets or sets the field name.
    Public Property Gets or sets a value indicating whether the field is highlighted.
    Public Property Gets or sets the number format.
    Public Property Gets or sets a value indicating whether the field is read only.
    Public Property Gets or sets a value indicating whether the values from this field should be included in the search.
    Public Property Gets or sets search mode to use when searching for values in this field.
    Public Property Gets or sets a value indicating whether the field value is a ratio (used only by geoprocessing).
    Public Property Gets or sets a value indicating whether the field is visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFieldDescription.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFieldDescription with a specified state from a JSON encoding.
    Public Methodstatic (Shared in Visual Basic) Gets the default field description for a given field.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFieldDescription and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
