ArcGIS.Core.Geometry Namespace / CompositeHVDatumTransformation Class / GetInverse Method
Example
    GetInverse Method (CompositeHVDatumTransformation)
    Creates an inverted instance of this HVDatumTransformation. The inverted instance has inverted order of HVDatumTransformation instances, and each hv datum transformation has its IsForward property inverted.
    Syntax
    Public Overrides NotOverridable Function GetInverse() As DatumTransformation
    public override DatumTransformation GetInverse()
    Return Value
    A DatumTransformation that is inverted.
    Example
    Create Composite HV Datum Transformation
      HVDatumTransformation hv1 = HVDatumTransformation.Create(108034);
      HVDatumTransformation hv2 = HVDatumTransformation.Create(108033, false);
      List<HVDatumTransformation> hvs = new List<HVDatumTransformation>() { hv1, hv2 };
      // create from enumeration
      CompositeHVDatumTransformation compositehv =
                      CompositeHVDatumTransformation.Create(hvs);
      int count = compositehv.Count;      // count = 2
      List<HVDatumTransformation> transforms =
                     compositehv.Transformations as List<HVDatumTransformation>;
      HVDatumTransformation tranform = transforms[0];
      // transform.Wkid = 108034
      // get inverse
      CompositeHVDatumTransformation inverse_compositehv =
             compositehv.GetInverse() as CompositeHVDatumTransformation;
      // create from xml
      string xml = compositehv.ToXml();
      var xml_compositehv = CompositeHVDatumTransformation.CreateFromXml(xml);
      // create from json
      string json = compositehv.ToJson();
      CompositeHVDatumTransformation json_compositehv =
          DatumTransformation.CreateFromJson(json) as CompositeHVDatumTransformation;
    Requirements
