ArcGIS.Core.CIM Namespace / CIMGridEndpoint Class
Properties Methods Events
    CIMGridEndpoint Class Members
    The following tables list the members exposed by CIMGridEndpoint.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to draw corner labels inside the map grid edges.
    Public Property Gets or sets a value indicating whether to draw the labels parallel to the map grid edges.
    Public Property Gets or sets a value indicating which labels to draw along the map grid edges.
    Public Property Gets or sets the grid label template for each endpoint.
    Public Property Gets or sets the end point selection.
    Public Property Gets or sets the offset of the labels.
    Public Property Gets or sets the position of the labels of the end points.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGridEndpoint.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGridEndpoint with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGridEndpoint and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
