ArcGIS.Desktop.Core Namespace / ArcGISPortalManager Class / EditPortal Method
The existing portal whose Uri will be changed
The URI to use to replace the existing Uri of the existingPortalObj
    EditPortal Method
    Change the Uri of the existing portal to be the new Portal Uri. This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Syntax
    Parameters
    existingPortalObj
    newPortalUri
    Return Value
    A ArcGISPortal with the changed Uri
    Exceptions
    ExceptionDescription
    Thrown when a method is called on the wrong Pro thread
    The portal Uri was invalid or there was an error changing the portal Uri
    Remarks
    The existing portal must currently be in the list of portals managed by the ArcGISPortalManager
    Requirements
