ArcGIS.Desktop.Core Namespace / ArcGISPortalManager Class / SetActivePortal Method
The portal to be set active
Example
    Sets the currently active portal. This will result in the ArcGIS.Desktop.Core.Events.ActivePortalChangedEvent being published. This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Syntax
    Public Function SetActivePortal( _
       ByVal portalObj As ArcGISPortal _
    ) As Boolean
    public bool SetActivePortal(
       ArcGISPortal portalObj
    Parameters
    portalObj
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called on a valid ArcGISPortal object. This object may have been edited or removed.
    Thrown when a method is called on the wrong Pro thread
    Example
    ArcGISPortalManager: Get a portal and Sign In, Set it Active
      //Find the portal to sign in with using its Uri...
      var uri = new Uri("http://myportal.esri.com/portal/", UriKind.Absolute);
      var aPortal = ArcGISPortalManager.Current.GetPortal(uri);
      if (!aPortal.IsSignedOn())
        //Calling "SignIn" will trigger the OAuth popup if your credentials are
        //not cached (eg from a previous sign in in the session)
        if (portal.SignIn().success)
          //Set this portal as my active portal
          ArcGISPortalManager.Current.SetActivePortal(portal);
    Requirements
