ArcGIS.Desktop.Core Namespace / Project Class / GetProjectItemContainer Method
The key for the given container
Example
    Get the container with the given key. Container keys are not localized. A container is needed only in those situations where you want to select a specific item that occurs in more than one container.
    Syntax
    public Item GetProjectItemContainer(
       string key
    Public Function GetProjectItemContainer( _
       ByVal key As String _
    ) As Item
    Parameters
    key
    Return Value
    The container Item or null
    Remarks
    Containers can vary from project to project depending on the content. Some containers, therefore, can be null. You can use the following keys to retrieve a container. Check for null.
    Public containers (not including any 3rd party custom containers):
    Display Name(English) Path or "Key" (Non-localizable) Item content
    Databases GDB Database content
    Folders FolderConnection Files and Folders
    Layouts Layout Layouts
    Locators LocatorsConnection Locators
    Maps Map Maps
    Raster Function Templates RasterFunctionTemplates Raster function templates
    Servers ServerConnection Server connections
    Styles Style Styles
    Tasks Task Tasks
    Toolboxes GP Toolboxes
    Workflows WorkflowConnection Workflows
    Example
    Get the Favorite StyleProjectItem
      await QueuedTask.Run(() =>
        var containerStyle = Project.Current.GetProjectItemContainer("Style");
        var fav_style_item = containerStyle.GetItems().OfType<StyleProjectItem>().First(item => item.TypeID == "personal_style");
    Select project containers - for use with SelectItemAsync
      //Use Project.Current.ProjectItemContainers
      var folderContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "FolderConnection");
      var gdbContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "GDB");
      var mapContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "Map");
      var layoutContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "Layout");
      var toolboxContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "GP");
      //etc.
      //or...use Project.Current.GetProjectItemContainer
      folderContainer = Project.Current.GetProjectItemContainer("FolderConnection");
      gdbContainer = Project.Current.GetProjectItemContainer("GDB");
      mapContainer = Project.Current.GetProjectItemContainer("Map");
      layoutContainer = Project.Current.GetProjectItemContainer("Layout");
      toolboxContainer = Project.Current.GetProjectItemContainer("GP");
      //etc.
    Requirements
