ArcGIS.Desktop.Mapping Namespace / CatalogLayer Class / GetCatalogDataset Method
Example
    Returns the underlying CatalogDataset that the catalog layer is pointing to. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public CatalogDataset GetCatalogDataset()
    Public Function GetCatalogDataset() As CatalogDataset
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    A CatalogDataset is a collection of catalog dataset items, modeled as objects with a polygon representing the item footprint. Each footprint feature's attributes are properties specific to the purpose, scope, and validation status of each dataset item
    Example
    Create Catalog Layer using CatalogDataset
      //Get the CatalogDataset of another Catalog layer
      var existingCatalogLayer = map.GetLayersAsFlattenedList().OfType<CatalogLayer>().FirstOrDefault();
      if (existingCatalogLayer != null)
        await QueuedTask.Run(() =>
          var catalogDataset = existingCatalogLayer.GetCatalogDataset();
          //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
          var catalogLyrParams = new CatalogLayerCreationParams(catalogDataset);
          catalogLyrParams.Name = "NewCatalogLayerFromAnotherCatalogLayer";
          catalogLyrParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'Asia'");
          LayerFactory.Instance.CreateLayer<CatalogLayer>(catalogLyrParams, map);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
