ArcGIS.Desktop.Mapping Namespace / SurfaceZsResultStatus Enumeration
Example Example
    Defines the status types resulting from calling Map.GetZsFromSurfaceAsync(). See SurfaceZsResult
    Syntax
    Members
    MemberDescription
    CalculationError Error: something went wrong when calculating, probably a SpatialReference issue.
    Canceled Information: the calculation was canceled, Zs are not available
    InvalidState Error: something went wrong internally.
    NoVisibleSourceThe specified ElevationSurfaceLayer has no visible elevation sources, all Zs were set to a constant value, Zs are available.
    Ok Calculation went fine, Zs are available.
    OutsideDomain Information: input is entirely outside the surface domain, Zs are not available.
    Example
    Get Elevation profile from the default ground surface
      // get the elevation profile for a polyline / set of polylines
      Polyline polyline = PolylineBuilderEx.CreatePolyline();
      MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
      List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
      if (result.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = result.Polyline;
        // process the polylineZ
        // get the elevation profile for a set of points
        result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
    Get Elevation profile from a specific surface
      // find a specific elevation surface layer
      var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
      // use the specific elevation surface layer
      var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
      if (zResult.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = zResult.Polyline;
      zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
    Interpolate a line between two points and calculate the elevation profile
      int numPoints = 20;//Or any number of points you want to interpolate
                         // use a specific elevation surface
      // use the default ground elevation surface
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
      result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
    Show Elevation profile graph using an ElevationProfileResult
      var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
      if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
        return;
      if (!MapView.Active.CanShowElevationProfileGraph())
        return;
      // show the elevation profile using the result
      MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Get Z values from a TIN Layer
      await QueuedTask.Run(() =>
        if (tinLayer.CanGetZs())
          // get z value for a mapPoint
          var zResult = tinLayer.GetZs(mapPoint);
            // cast to a mapPoint
            var mapPointZ = zResult.Geometry as MapPoint;
            var z = mapPointZ.Z;
          // get z values for a polyline
          zResult = tinLayer.GetZs(polyline);
            // cast to a Polyline
            var polylineZ = zResult.Geometry as Polyline;
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.SurfaceZsResultStatus
    Requirements
