ArcGIS.Core.CIM Namespace / CIMMap Class / HVDatumTransforms Property
Example
    Gets or sets the set of geographic transformations used by the map for spatial references with vertical coordinate system.
    Syntax
    public CompositeHVDatumTransformation[] HVDatumTransforms {get; set;}
    Public Property HVDatumTransforms As CompositeHVDatumTransformation()
    Remarks
    An object with an empty Transformations list indicates the "Do not transform" case, where a pair of coordinate systems is deliberately configured so that no coordinate transformation occurs during projection.
    Example
    Datum
      var cimMapDefinition = MapView.Active.Map.GetDefinition();
      // use if map's sr does not have a vertical coordinate system
      var datumTransformations = cimMapDefinition.DatumTransforms;
      // use if map's sr has a vertical coordinate system
      var hvDatumTransformations = cimMapDefinition.HVDatumTransforms;
    Requirements
