ArcGIS.Desktop.Mapping.Controls Namespace / CoordinateSystemsControlProperties Class / Wkid Property
    Wkid Property (CoordinateSystemsControlProperties)
    Gets and sets the spatial reference wkid to be used to select the SpatialReference in the CoordinateSystemsControl.
    Syntax
    public int Wkid {get; set;}
    Public Property Wkid As Integer
    Remarks
    SpatialReference wkid is optional. The default is 0. If the SpatialReference wkid is set then the corresponding SpatialReference with that wkid will be selected in the CoordinateSystemsControl.
    Note: only one of: o SpatialReference
    o Wkid
    o Wkt
    need be set.
    If the SpatialReference is set, Wkid and Wkt are ignored. If the SpatialReference is null, then Wkid is used. If the Wkid is 0 (or less), then the Wkt is used.
    If no SpatialReference is set then the first SpatialReference of the first layer in the provided map is selected. If no map is provided then no SpatialReference is selected.
    Requirements
