ArcGIS.Core.Data.Raster Namespace / Raster Class / CreateCursor Method
Width of the pixel block in the raster cursor.
Height of the pixel block in the raster cursor.
Example
    CreateCursor Method
    Create a RasterCursor for optimized access to raster pixels. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateCursor( _
       ByVal blockWidth As Integer, _
       ByVal blockHeight As Integer _
    ) As RasterCursor
    public RasterCursor CreateCursor(
       int blockWidth,
       int blockHeight
    Parameters
    blockWidth
    blockHeight
    Return Value
    The RasterCursor for optimized access to raster pixels.
    Example
    Create a raster cursor to iterate through the raster data
    await QueuedTask.Run(() =>
      // Create a full raster from the raster dataset.
      ArcGIS.Core.Data.Raster.Raster raster = rasterDataset.CreateFullRaster();
      // Calculate size of pixel blocks to process. Use 1000 or height/width of the raster, whichever is smaller.
      var height = raster.GetHeight();
      var width = raster.GetWidth();
      int pixelBlockHeight = height > 1000 ? 1000 : height;
      int pixelBlockWidth = width > 1000 ? 1000 : width;
      // Create the raster cursor using the height and width calculated.
      RasterCursor rasterCursor = raster.CreateCursor(pixelBlockWidth, pixelBlockHeight);
      // Use a do-while loop to iterate through the pixel blocks of the raster using the raster cursor.
      do
        // Get the current pixel block from the cursor.
        using (PixelBlock currentPixelBlock = rasterCursor.Current)
          // Do something with the pixel block...
        // Once you are done, move to the next pixel block.
      while (rasterCursor.MoveNext());
    Requirements
