ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GetSubCurve3D Method
The 3D multipart from which the subcurve will be extracted.
The distance along the multipart to start the subcurve.
The distance along the multipart to end the subcurve.
Indicates whether the fromDistance and toDistance are given as lengths or ratios along the multipart.
Example
    GetSubCurve3D Method (IGeometryEngine)
    Gets the 3D subcurve of the input multipart between fromDistance and toDistance.
    Syntax
    Parameters
    multipart
    fromDistance
    toDistance
    asRatioOrLength
    Return Value
    The 3D polyline representing the subcurve.
    Exceptions
    ExceptionDescription
    Multipart is null or empty.
    This geometry is not Z-Aware.
    Cannot do 3D operations on curve segments.
    Example
    Get Sub-curve of a polyline or polygon
      SpatialReference sr = SpatialReferences.WGS84;
      List<Coordinate2D> coords =
        new Coordinate2D(-111, 72),
      new Coordinate2D(-108, 68),
      new Coordinate2D(-114, 68)
      polyline = PolylineBuilderEx.CreatePolyline(coords, sr);
      Polyline subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 5, AsRatioOrLength.AsLength);
      // subCurve.PartCount = 1
      // subCurve.PointCount = 2
      ReadOnlyPointCollection points = subCurve.Points;
      // points[0] = -111, 72
      // points[1] = -108, 68
      subCurve = GeometryEngine.Instance.GetSubCurve(polyline, 0, 0.5, AsRatioOrLength.AsRatio);
      // subCurve.PointCount = 3
      // points[2] = -108.5, 68
      List<Coordinate3D> coords3D =
        new Coordinate3D(0, 0, 0),
      new Coordinate3D(0, 1, 1),
      new Coordinate3D(1, 1, 2),
      new Coordinate3D(1, 0, 3)
      polygon = PolygonBuilderEx.CreatePolygon(coords3D, sr);
      subCurve = GeometryEngine.Instance.GetSubCurve3D(polygon, 0, 1, AsRatioOrLength.AsLength);
      // subCurve.HasZ = true
      // points.Count = 2
      // points[0] = 0, 0, 0
      // points[1] = 0, 0.70710678118654746, 0.70710678118654746
    Requirements
