ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CanCopyLayer Method
The layer to be checked
    CanCopyLayer Method (ILayerFactory)
    Gets if the the layer can be copied. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    bool CanCopyLayer(
       Layer layer
    Function CanCopyLayer( _
       ByVal layer As Layer _
    ) As Boolean
    Parameters
    layer
    Return Value
    True if the layer can be copied
    Exceptions
    ExceptionDescription
    Requirements
