ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface
Methods
    ILayerFactory Interface Members
    The following tables list the members exposed by ILayerFactory.
    Public Methods
     NameDescription
     Method Gets if the the layer can be copied. This method must be called on the MCT. Use QueuedTask.Run.
     Method Indicates whether a layer can be created using the specified LayerCreationParams and added to the container. This method must be called on the MCT. Use QueuedTask.Run.
     Method Indicates whether a layer can be created from an Item.
     MethodIndicates whether Layers can be created using the specified BulkLayerCreationParams and added to the container.
     Method Copy a layer. This method must be called on the MCT. Use QueuedTask.Run.
     Method Create a group layer. This method must be called on the MCT. Use QueuedTask.Run.
     MethodOverloaded.
     MethodOverloaded.
    Top
