ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CanCreateLayers Method
A BulkLayerCreationParams object.
A map or group layer where the Layers will be added.
    CanCreateLayers Method (ILayerFactory)
    Indicates whether Layers can be created using the specified BulkLayerCreationParams and added to the container.
    Syntax
    Parameters
    layerParams
    container
    Return Value
    A boolean indicating that Layers can be created.
    Remarks
    You should use this method before passing an item to LayerFactory.CreateLayers
    Requirements
    ArcGIS Pro version: 3.4 or higher.
