ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CanCreateLayer<T> Method
Expected Layer Type
Can be one of LayerCreationParams derived objects.
A map or group layer instance to which the Layer will be added.
    CanCreateLayer<T> Method (ILayerFactory)
    Indicates whether a layer can be created using the specified LayerCreationParams and added to the container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    layerParams
    container
    Type Parameters
    T
    Expected Layer Type
    Return Value
    A boolean indicates that a layer can be created.
    Exceptions
    ExceptionDescription
    LayerCreationParams or container is null.
    Cannot create the layer of the specified type with the set of LayerCreationParams.
    Remarks
    You should use this method before passing an item to LayerFactory.CreateLayer<T>
    Requirements
    ArcGIS Pro version: 3.3 or higher.
