ArcGIS.Desktop.Mapping Namespace / IMapFactory Interface / CopyMap Method
The map to be copied
    CopyMap Method (IMapFactory)
    Copies the input map and adds it to the project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function CopyMap( _
       ByVal map As Map _
    ) As Map
    Map CopyMap(
       Map map
    Parameters
    map
    Return Value
    Map
    Exceptions
    ExceptionDescription
    The map is null.
    Remarks
    Use FrameworkApplication.Panes.CreateMapPaneAsync(mapCopy) to activate the newly copied map (if needed)
    Requirements
