ArcGIS.Desktop.Mapping Namespace / Map Class / GetHighlightSelection Method
    Get the highlight selection for the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public SelectionSet GetHighlightSelection()
    Public Function GetHighlightSelection() As SelectionSet
    Return Value
    The highlighted selection in the map represented by the collection of layers and tables and their corresponding object ids.
    Exceptions
    ExceptionDescription
    Requirements
