ArcGIS.Desktop.Mapping Namespace / StyleHelper Class / SearchColorRamps Method
The StyleProjectItem to search.
The search term.
Example
    Returns a collection of color ramp style items that satisfy the search criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    styleProjectItem
    searchString
    The search term.
    Return Value
    A collection of ColorRampStyleItem.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Example
    How to search for color ramps in a style
      //StyleProjectItem can be "ColorBrewer Schemes (RGB)", "ArcGIS 2D"...
      //Search for color ramps
      //Color Ramp searchString can be "Spectral (7 Classes)", "Pastel 1 (3 Classes)", "Red-Gray (10 Classes)"..
      styleProjectItem.SearchColorRamps("searchString");
    How to apply a color ramp from a style to a feature layer
      List<string> fields = new List<string>() { "Field1" };
      var project = Project.Current;
      await QueuedTask.Run(() =>
        StyleProjectItem styleToUse =
          project.GetItems<StyleProjectItem>()
              .FirstOrDefault(s => s.Name == "ColorBrewer Schemes (RGB)");
        if (style == null)
          return;
        var colorRampListFound = styleToUse.SearchColorRamps("Red-Gray (10 Classes)");
        if (colorRampListFound == null || colorRampListFound.Count == 0)
          return;
        CIMColorRamp cimColorRamp = null;
        CIMRenderer renderer = null;
        cimColorRamp = colorRampListFound[0].ColorRamp;
        var rendererDef = new UniqueValueRendererDefinition(fields, null, cimColorRamp);
        renderer = featureLayer?.CreateRenderer(rendererDef);
        featureLayer?.SetRenderer(renderer);
    Create a feature layer with class breaks renderer
      string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
      StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
      string colorRampName = "Greens (Continuous)";
      IList<ColorRampStyleItem> colorRampListFromTheStyle = await QueuedTask.Run(() =>
        colorBrewerStyle.SearchColorRamps(colorRampName));
      ColorRampStyleItem colorRampFound = colorRampList[0];
      GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
        ClassificationField = "CROP_ACR07",
        ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
        BreakCount = 6,
        ColorRamp = colorRampFound.ColorRamp,
        SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
        ExclusionClause = "CROP_ACR07 = -99",
        ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
        ExclusionLabel = "No yield",
      var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
        Name = "Crop",
        RendererDefinition = gcDef
        LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, map));
    Create a new colorizer based on a custom colorizer definition and apply it to the raster layer
      // Check if the Stretch colorizer can be applied to the raster layer.
      //Get a color ramp from a style
      StyleProjectItem ArcGISColorsStyleItem =
            project.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
      await QueuedTask.Run(async () =>
        var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
        CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
        if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
          // Create a new Stretch Colorizer Definition specifying parameters
          // for band index, stretch type, gamma and color ramp.
          StretchColorizerDefinition stretchColorizerDef_custom =
            new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
          // Create a new stretch colorizer using the colorizer definition created above.
          CIMRasterStretchColorizer newStretchColorizer_custom =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          // Set the new colorizer on the raster layer.
          rasterLayer.SetColorizer(newStretchColorizer_custom);
    Create and Set a Stretch Renderer
      var currentProject = Project.Current;
      if (currentProject == null)
        return;
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                                PointCloudRendererType.StretchRenderer);
        var stretchDef = new PointCloudRendererDefinition(
          //Will be either ELEVATION or INTENSITY
          Field = fields[0]
        //Create the CIM Renderer
        var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
                                            as CIMPointCloudStretchRenderer;
        //Apply a color ramp
        var style = currentProject.GetItems<StyleProjectItem>()
                                        .First(s => s.Name == "ArcGIS Colors");
        var colorRamp = style.SearchColorRamps("").First();
        stretchRenderer.ColorRamp = colorRamp.ColorRamp;
        //Apply modulation
        stretchRenderer.ColorModulation = new CIMColorModulationInfo()
          MinValue = 0,
          MaxValue = 100
        //apply the renderer
        pointCloudSceneLayer.SetRenderer(stretchRenderer);
    Requirements
