ArcGIS.Core.CIM Namespace / CIMGeotriggerNotificationProperties Class
Properties Methods Events
    CIMGeotriggerNotificationProperties Class Members
    The following tables list the members exposed by CIMGeotriggerNotificationProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the arcade expression which can be used to configure notification information when the Geotrigger condition is met. The expression uses the Geotrigger Notification Arcade profile.
    Public Property Gets or sets list of recommended actions that the author intends to be taken for this Geotrigger. Actions can be any strings that are supported by geotrigger enabled apps in your organization and should cover all possible 'action' values returned from evaluation of expressionInfo.expression.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeotriggerNotificationProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeotriggerNotificationProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeotriggerNotificationProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
