ArcGIS.Desktop.Mapping Namespace / ILayerFactory Interface / CreateLayer Method / CreateLayer(Uri,ILayerContainerEdit,Int32,String) Method
An URI represents the path or url to a dataset or .lyrx or .lpkx file.
A map or group layer instance where the Layer will be added
The position of the layer in the map or group layer. 0 represents the top most position.
(optional) When it is not provided, the default display name gets used e.g. the dataset name or alias. (default value = "")
Example
    Creates a new Layer instance with the specified path to a dataset and adds it to a container such as a map or a group layer. Optionally you can provide a name to override the default display name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function CreateLayer( _
       ByVal dataUri As Uri, _
       ByVal container As ILayerContainerEdit, _
       Optional ByVal index As Integer, _
       Optional ByVal layerName As String _
    ) As Layer
    Parameters
    dataUri
    container
    index
    layerName
    Exceptions
    ExceptionDescription
    DataUri or container is null.
    Example
    Create and add a layer to the active map
      //* string url = @"c:\data\project.gdb\DEM";  //Raster dataset from a FileGeodatabase
      //* string url = @"c:\connections\mySDEConnection.sde\roads";  //FeatureClass of a SDE
      //* string url = @"c:\connections\mySDEConnection.sde\States\roads";  //FeatureClass within a FeatureDataset from a SDE
      //* string url = @"c:\data\roads.shp";  //Shapefile
      //* string url = @"c:\data\imagery.tif";  //Image from a folder
      //* string url = @"c:\data\mySDEConnection.sde\roads";  //.lyrx or .lpkx file
      //* string url = @"c:\data\CAD\Charlottesville\N1W1.dwg\Polyline";  //FeatureClass in a CAD dwg file
      //* string url = @"C:\data\CAD\UrbanHouse.rvt\Architectural\Windows"; //Features in a Revit file
      //* string url = @"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";  //map service
      //* string url = @"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0";  //FeatureLayer off a map service or feature service
      string urlRoads = @"c:\data\project.gdb\roads";  //FeatureClass of a FileGeodatabase
      Uri uri = new Uri(urlRoads);
      var newLayer = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer(uri, map));
    Create a raster layer
      string urlRatser = @"C:\Images\Italy.tif";
        // Create a raster layer using a path to an image.
        // Note: You can create a raster layer from a url, project item, or data connection.
        var rasterLayerToCreate = LayerFactory.Instance.CreateLayer(new Uri(urlRatser), map) as RasterLayer;
    Create a mosaic layer
      //Path to mosaic dataset
      string urlItaly = @"C:\Images\countries.gdb\Italy";
      // Create a mosaic layer using a path to a mosaic dataset.
      // Note: You can create a mosaic layer from a url, project item, or data connection.
      mosaicLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer(new Uri(urlItaly), map) as MosaicLayer);
    Create an image service layer
      string urlToUse =
      @"http://imagery.arcgisonline.com/arcgis/services/LandsatGLS/GLS2010_Enhanced/ImageServer";
      // Create an image service layer using the url for an image service.
      var isLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer(new Uri(urlToUse), map) as ImageServiceLayer);
    Create Stream Layer with URI
        var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var createParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = false //turned off by default
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(createParam, map);
        //or use "original" create layer (will be visible by default)
        Uri uri = new Uri(url);
        streamLayer = LayerFactory.Instance.CreateLayer(uri, map) as StreamLayer;
        streamLayer.SetVisibility(false);//turn off
    Requirements
