ArcGIS.Core.CIM Namespace / CIMColorModulationInfo Class / MinValue Property
Example
    MinValue Property (CIMColorModulationInfo)
    Gets or sets the minimum value to compute modulation on linear scale based on field value.
    Syntax
    public double MinValue {get; set;}
    Public Property MinValue As Double
    Example
    Create and Set a Stretch Renderer
      var currentProject = Project.Current;
      if (currentProject == null)
        return;
      await QueuedTask.Run(() =>
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                                PointCloudRendererType.StretchRenderer);
        var stretchDef = new PointCloudRendererDefinition(
          //Will be either ELEVATION or INTENSITY
          Field = fields[0]
        //Create the CIM Renderer
        var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
                                            as CIMPointCloudStretchRenderer;
        //Apply a color ramp
        var style = currentProject.GetItems<StyleProjectItem>()
                                        .First(s => s.Name == "ArcGIS Colors");
        var colorRamp = style.SearchColorRamps("").First();
        stretchRenderer.ColorRamp = colorRamp.ColorRamp;
        //Apply modulation
        stretchRenderer.ColorModulation = new CIMColorModulationInfo()
          MinValue = 0,
          MaxValue = 100
        //apply the renderer
        pointCloudSceneLayer.SetRenderer(stretchRenderer);
    Edit Color Modulation
        var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
        //Get the ColorModulation off the renderer
        var modulation = def.Renderer.ColorModulation;
        if (modulation == null)
          modulation = new CIMColorModulationInfo();
        //Set the minimum and maximum intensity as needed
        modulation.MinValue = 0;
        modulation.MaxValue = 100.0;
        //apply back
        def.Renderer.ColorModulation = modulation;
        //Commit changes back to the CIM
        pointCloudSceneLayer.SetDefinition(def);
    Requirements
