ArcGIS.Core.CIM Namespace / CIMStandaloneVideo Class
Properties Methods Events
    CIMStandaloneVideo Class Members
    The following tables list the members exposed by CIMStandaloneVideo.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the collection of event indicators for Bookmark.
    Public Property Gets or sets the data connection for the video.
    Public Property Gets or sets the elapsed time in seconds.
    Public Property Gets or sets a value indicating whether the standalone video is expanded in the contents pane.
    Public Property Gets or sets the collection of event indicators for ExportFrame.
    Public Property Gets or sets the collection of range indicators for ExportFrames.
    Public Property Gets or sets the collection of range indicators for ExportSegment.
    Public Property Gets or sets the collection of event indicators for ExportToPPT.
    Public Property Gets or sets the footprint color.
    Public Property Gets or sets the graphic element representing the frame center.
    Public Property Gets or sets the graphic element representing the frame outline.
    Public Property Gets or sets the collection of range indicators for MetadataToCSV.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the graphic element representing the platform position.
    Public Property Gets or sets the graphic element representing the platform trail.
    Public Property Gets or sets the collection of range indicators for RecordSegments.
    Public Property Gets or sets the collection of range indicators for RecordVideo.
    Public Property Gets or sets the collection of selected Key-Length-Value (KLV) channels.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the standalone video graphics is visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStandaloneVideo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStandaloneVideo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStandaloneVideo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
