await QueuedTask.Run(async () =>
//The fields in the datasource used for the report
//This uses a US Cities dataset
var listFields = new List<CIMReportField> {
//Grouping should be the first field
new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
new CIMReportField{Name = "POP1990", FieldOrder = 2, },
//Definition query to use for the data source
var defQuery = "STATE_NAME LIKE 'C%'";
//Define the Datasource
var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
//The CIMPage defintion - page size, units, etc
var cimReportPage = new CIMPage
Height = 11,
StretchElements = false,
Width = 6.5,
ShowRulers = true,
ShowGuides = true,
Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
Units = LinearUnit.Inches
//Report template
var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
//Report Styling
var reportStyles = await ReportStylingManager.GetStylingsAsync();
var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
//Field Statistics
var fieldStatisticsList = new List<ReportFieldStatistic> {
new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
//Note: NoStatistics option for FieldStatisticsFlag is not supported.
var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
//This is the gap between two fields
double fieldIncrement = 0.9388875113593206276389;
await QueuedTask.Run(() =>
//New field to add.
var newReportField = new CIMReportField
Name = "POP1990",
FieldOrder = 2,
//Get the "ReportSection element"
var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
if (mainReportSection == null)
return;
//Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
if (reportDetailsSection == null)
return;
//Within ReportDetails find the envelope that encloses a field.
//We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
var gr = r as GraphicElement;
if (gr == null)
return false;
return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
//Get the Envelope of the last field
var graphicBounds = lastFieldGraphic.GetBounds();
//Min and Max values of the envelope
var xMinOfFieldEnvelope = graphicBounds.XMin;
var yMinOfFieldEnvelope = graphicBounds.YMin;
var xMaxOfFieldEnvelope = graphicBounds.XMax;
var YMaxOfFieldEnvelope = graphicBounds.YMax;
//create the new Envelope to be offset from the existing field
MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
//Create field
GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
