ArcGIS.Core.CIM Namespace / CIMTableField Class
Properties Methods Events
    CIMTableField Class Members
    The following tables list the members exposed by CIMTableField.
    Public Properties
     NameDescription
    Public Property Gets or sets the display name for the field.
    Public Property Gets or sets the zero based display order.
    Public Property Gets or sets a value indicating whether this is a grouping field.
    Public Property Gets or sets a value indicating whether the field is visible.
    Public Property Gets or sets the field name and unique identifier.
    Public Property Gets or sets the options when this field is used for sorting.
    Public Property Gets or sets the zero based sort order. -1 indicates field isn't used for sorting.
    Public Property Gets or sets the width of field. A value of 0 indicates "auto size".
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
