ArcGIS.Core.CIM Namespace / CIMTableField Class / Name Property
Example
    Name Property (CIMTableField)
    Gets or sets the field name and unique identifier.
    Syntax
    public string Name {get; set;}
    Public Property Name As String
    Example
    Create report
      await QueuedTask.Run(async () =>
        //The fields in the datasource used for the report
        //This uses a US Cities dataset
        var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
        //Definition query to use for the data source
        var defQuery = "STATE_NAME LIKE 'C%'";
        //Define the Datasource
        var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
        //The CIMPage defintion - page size, units, etc
        var cimReportPage = new CIMPage
          Height = 11,
          StretchElements = false,
          Width = 6.5,
          ShowRulers = true,
          ShowGuides = true,
          Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
          Units = LinearUnit.Inches
        //Report template
        var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
        var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
        //Report Styling
        var reportStyles = await ReportStylingManager.GetStylingsAsync();
        var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
        //Field Statistics
        var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
        var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Create a new field in the report
      //This is the gap between two fields
      double fieldIncrement = 0.9388875113593206276389;
      await QueuedTask.Run(() =>
        //New field to add.
        var newReportField = new CIMReportField
          Name = "POP1990",
          FieldOrder = 2,
        //Get the "ReportSection element"
        var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
        if (mainReportSection == null)
          return;
        //Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
        var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
        if (reportDetailsSection == null)
          return;
        //Within ReportDetails find the envelope that encloses a field.
        //We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
        var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
          var gr = r as GraphicElement;
          if (gr == null)
            return false;
          return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
        //Get the Envelope of the last field
        var graphicBounds = lastFieldGraphic.GetBounds();
        //Min and Max values of the envelope
        var xMinOfFieldEnvelope = graphicBounds.XMin;
        var yMinOfFieldEnvelope = graphicBounds.YMin;
        var xMaxOfFieldEnvelope = graphicBounds.XMax;
        var YMaxOfFieldEnvelope = graphicBounds.YMax;
        //create the new Envelope to be offset from the existing field
        MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
        MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
        Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
        //Create field
        GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
    Requirements
