ArcGIS.Desktop.Core Namespace / Project Class / FindItem(String) Method
The path to the item on disk
Example
    Find the item identified by the physical path.
    Syntax
    public Item FindItem(
       string path
    Public Function FindItem( _
       ByVal path As String _
    ) As Item
    Parameters
    path
    Return Value
    Remarks
    FindItem first looks in the Project index. If the item is not found, FindItem browses for the item on disk.
    Note: If the path corresponds to a folder or file geodatabase not currently added to the project, the item, if found, will be added to the project (and will be indexed)
    Example
    ProjectItem: Get an Item or Find an Item
      //GetItems searches project content
      var map = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "Map1");
      var layout = Project.Current.GetItems<LayoutProjectItem>().FirstOrDefault(m => m.Name == "Layout1");
      var folders = Project.Current.GetItems<FolderConnectionProjectItem>();
      var style = Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 3D");
      //Find item uses a catalog path. The path can be to a file or dataset
      var fcPath = @"C:\Pro\CommunitySampleData\Interacting with Maps\Interacting with Maps.gdb\Crimes";
      var pdfPath = @"C:\Temp\Layout1.pdf";
      var imgPath = @"C:\Temp\AddinDesktop16.png";
      var fc = Project.Current.FindItem(fcPath);
      var pdf = Project.Current.FindItem(pdfPath);
      var img = Project.Current.FindItem(imgPath);
    Requirements
