ArcGIS.Core.Data.UtilityNetwork Namespace / SubnetworkManager Class / GetSubnetworks Method
The specified tier from which to retrieve the subnetworks.
The states the subnetworks to be retrieved are in.
    Gets the list of Subnetwork in the Tier specified by tier whose SubnetworkStates are in subnetworkStates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    tier
    subnetworkStates
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
