Public Function GetTraceManager() As TraceManager
public TraceManager GetTraceManager()
Return Value
A ArcGIS.Core.Data.UtilityNetwork.Trace.TraceManager object that can be used to perform traces.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
// This routine creates a DownstreamTracer object from a UtilityNetwork
static void CreateADownstreamTracerObject(UtilityNetwork utilityNetwork)
using TraceManager traceManager = utilityNetwork.GetTraceManager();
DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
